I downloaded Netdrive, when i dubbelclick the .exe file to install, I get the following error message:
Failed to install vcredist14_x86.exe
This also occurs when I run installation with administrative privileges
I’ve got the same problem.
I have the same problem on my computer. It’s a PC running on Windows 7. I have all the admin privileges. I installed it on a Windows 10 environment without any problem.
Can you help?
Could you refer to the following url?
If this issue persists, could you let me show a screen shot which version “Microsoft Visual C++ redistributable” are installed?
