I connect and Mount my google drive as a network drive.
But when I want to disconnect it.
It gives me an error access denied
I also can’t disconnect it via network drive 3 because it shows Not Connected even though I can see my drive on network locations
What should I do to disconnect it?
February 7, 2022, 10:02pm
2
