When copying a folder from Explorer to an S3 bucket, a 0x800703EE error occurs. How can I fix it?
- NetDrive Version: 3.8.925
- OS: Windows10 Ent 1803
This error did not occur in the old version (3.7.687).
Isn’t it due to some specification change?
same here, installed noch 3.7x and all is fine
when will be fixed?
If you have a same problem, could you attach debug log files to figure out what happened?
Please refer to above post.
