I have a NET Drive license and using it on a daily basis.
However , I get an error message every now and then that files are not uploaded (Thus staying only on my local drive).
This is an example :
Now that I have quite a few files resides only on my local machine , How do I force net drive to scan all file and upload all files which were not synced to the cloud ? (our cloud is aws S3)
Thanks
Sagi
tsjeong
February 27, 2020, 8:59am
Dear sagikarni76,
OK,
But is there a way to force a sync so files that are only stored locally will be forced to be uploaded ?
Sagi
tsjeong
February 28, 2020, 4:31am
6
Dear sagikarni76,
Files that failed to upload can be retried on the UPLOADING page.
In NetDrive, files are always uploaded to the server. If you attach a log file for the failed situation, we will look at what is causing the problem.
March 6, 2020, 4:31am
7
