Using Netdrive 3 over WebDAV to map a drive to my Synology NAS from outside my LAN. Connection works fine. When ripping CDs (via dBpoweramp) and writing to the mapped drive on the NAS, I consistently get a “failed to upload” error for several of the tracks (sometimes all). When I look at the files in the folder via Windows Explorer, they are all there, and playback of the tracks works fine. dBpoweramp reports no problems.
Any ideas on what is causing these false error messages?
Thank you. Attached is the VERBOSE log file for a CD I just ripped with 14 tracks- 8 of which generated the “failed to upload” message (2,3,6,8,11,12,14). They were ripped in order, tracks 1-14.
_nd3svc_PARENT.log (3.2 KB)
ndagent.log (79.3 KB)
nd3svc_BlazakNAS- Remote.log (4.2 MB)
January 24, 2018, 8:16am
6
Dear chris-blazak
Your uploading requests was time outed.
Please check your NAS server or network environment.
Line 17646: [2018/01/23 19:49:20.109] [MESSAGE ] [ 17000] [FILESYSTEM] AsyncJobUpload - 04 - The Tracks of My Tears.m4a() done(Failed)
Line 18281: [2018/01/23 19:49:21.504] [MESSAGE ] [ 7108] [FILESYSTEM] AsyncJobUpload - 03 - Good Lovin'.m4a() done(Failed)
Line 19094: [2018/01/23 19:49:29.490] [MESSAGE ] [ 12772] [FILESYSTEM] AsyncJobUpload - 01 - I Heard It Through the Grapevine.m4a() done(Failed)
Line 19787: [2018/01/23 19:49:31.515] [MESSAGE ] [ 1140] [FILESYSTEM] AsyncJobUpload - 02 - My Girl.m4a() done(Failed)
Line 20359: [2018/01/23 19:49:47.137] [MESSAGE ] [ 17000] [FILESYSTEM] AsyncJobUpload - 05 - Joy to the World.m4a() done(Failed)
Line 20930: [2018/01/23 19:49:52.496] [MESSAGE ] [ 12772] [FILESYSTEM] AsyncJobUpload - 07 - (You Make Me Feel Like A) Natural Woman.m4a() done(Failed)
Line 21501: [2018/01/23 19:49:55.518] [MESSAGE ] [ 7108] [FILESYSTEM] AsyncJobUpload - 06 - Ain't Too Proud to Beg.m4a() done(Failed)
Line 22068: [2018/01/23 19:50:00.535] [MESSAGE ] [ 1140] [FILESYSTEM] AsyncJobUpload - 08 - I Second That Emotion.m4a() done(Failed)
Line 22647: [2018/01/23 19:50:14.140] [MESSAGE ] [ 17000] [FILESYSTEM] AsyncJobUpload - 09 - A Whiter Shade of Pale.m4a() done(Failed)
Line 23218: [2018/01/23 19:50:15.509] [MESSAGE ] [ 12772] [FILESYSTEM] AsyncJobUpload - 10 - Tell Him.m4a() done(Failed)
Line 23786: [2018/01/23 19:50:18.524] [MESSAGE ] [ 7108] [FILESYSTEM] AsyncJobUpload - 11 - It's the Same Old Song.m4a() done(Failed)
Line 24351: [2018/01/23 19:50:27.541] [MESSAGE ] [ 1140] [FILESYSTEM] AsyncJobUpload - 12 - Dancing in the Street.m4a() done(Failed)
Line 24920: [2018/01/23 19:50:41.164] [MESSAGE ] [ 17000] [FILESYSTEM] AsyncJobUpload - 13 - What's Going On.m4a() done(Failed)
Line 25485: [2018/01/23 19:50:43.518] [MESSAGE ] [ 12772] [FILESYSTEM] AsyncJobUpload - 14 - Too Many Fish in the Sea.m4a() done(Failed)
OK- many thanks for the analysis. I have modified my home network setup and seeing fewer exceptions now, though still some. However, all of the tracks have been successfully written.
