I try to upload/register files, pictures from my laptop to my synology diskstation unsuccessfully. (start to download and fail after few seconds 10/20sec)
I’ve tried by the HTTP and HTTPS way. Same problem
I really need a quick solution please.
I cant work like this.
Thank you
Alex
January 29, 2018, 2:15am
#2
Change Log Level
Get back to DRIVES screen
Changed log level takes effect when you leave SETTINGS screen.
Reproduce your problem !
After changing log level you must repeat your steps to reproduce the problem you have. This time it will be logged in relevant log files.
Send Log File
Within your driv…
closed
February 5, 2018, 2:15am
#3
