Hi
NAS (Router: NETGEAR + NAS: ipTIME)
Drive connection to WebDAB is not writable.
There is an error in rename or save etc.
However, the connection to the FTP drive is working fine.
What is the problem ???
Hi
Please check if you configured your drive item with read-only option.
I must have chosen Writable Drive,
But Writable is disabled.
Hello xerone
Did you use “Writable drive”?
If you cannot write even though you use “Writable drive” option, could you attach debug log files to figure out what happened?
I will review your log as soon as possible.
According your log files, HTTP 502 error occurred when MOVE operation is requested.
The error is blow.
<html>
<head>
<title>502 - Bad Gateway</title>
</head>
<body>
<h1>502 - Bad Gateway</h1>
</body>
</html>
I recommend to check your webdav server.
I am a beginner who does not understand your answer very difficultly.
So it focuses on two aspects:
I would like to be able to use a beginner like me without problems.
On the same NetDrive3, it is writable on ftp connections
It should not be a WebDAV connection.
A similar program, RaiDrive (free)
Writable is good with WebDAV connections.
https://www.raidrive.com/
We ask for resolution.PLS
Could you try with the following test version?
http://files.bdrive.com/netdrive/builds/faeb9a868e2745f8a7b69e0fb1cb6a7e/NetDrive3_Setup-3.8.710.exe
Even with v3.8.710
The same symptom (WebDAB-Writable disabled).
Troubleshooting
Please refer to RaiDrive (benchmark?)
And
Writable on Android Phone.
Samsung Galaxy Note9 (Pie 9)
APP: Total Commander plugin WebDAB
If possible, could you give me a test account to solve it?
Thank you for help
I will check it as soon as possible.
Hello xerone
I think you are happy with the following url version.
http://files.bdrive.com/netdrive/builds/1b8dac9a22394616b9a6d109da7f7ebd/NetDrive3_Setup-3.8.711.exe
The above version is a beta version.
It will be included in the next release version.
TYVM!!!
This v3.8.711 is very satisfied.
Please keep it in future update.
RaiDrive removed.
I sincerely appreciate this response.
Reliability is a vertical rise.
I am really happy.
You’re welcome.
If you have any problem, don’t hesitate to contact us.
