Hello there,
I have been using CloudSync with multiple cloud storage providers for a few months now; and I have encountered some recurring issues that I hope the community can help me with.
The first problem is that synchronization between these cloud services and my local files often seems to lag. I am noticing delays of up to an hour before files uploaded to one service show up in the corresponding folders of the others.
This is particularly troublesome when I am working on time-sensitive projects that require immediate syncing across platforms. Has anyone else experienced similar delays; and if so; how did you address them? ![]()
Another issue is that some files are not syncing at all; especially larger files. They seem to get stuck in a perpetual syncing status without ever completing the process.
I have tried restarting the CloudSync app and even disconnecting and reconnecting the cloud accounts, but the problem persists. Are there specific settings or troubleshooting steps I might be missing that could resolve this? ![]()
Lastly, I have also noticed that occasionally; the file versioning between different cloud providers is inconsistent. A file I updated on Dropbox may not reflect the same changes when I access it through Google Drive or OneDrive.
Also, I have gone through this post; https://support.bdrive.com/t/cloudsync-osx-does-not-sync-everything-uipath/ which definitely helped me out a lot.
This is causing a lot of confusion and could potentially lead to data loss if not addressed. Has anyone found a reliable way to maintain consistent file versions across different services? ![]()
Thanks in advance for your help and assistance. ![]()
