I have installed Netdrive3 and updated to the latest version, however, when i try to add my webdav account the program just sits there with the circle trying to connect. i have left this running for hours and still no progress.
I have restarted the machine and added the webdav via Windows Explorer without any issue.
This is a brand new laptop with all windows updates installed.
3.12.321 - doesnt work
3.9.1190 - doesnt work
3.7.687 - works!
guess i will have to avoid updates until a fix is in place.
tsjeong
September 15, 2020, 12:28pm
3
Dear 1ca5-support,
If you want to know what problem is, attach debug log files to figure out what happened.
September 22, 2020, 12:28pm
