SFTP Connection stop working.
To help us diagnose the issue, please set the log level to VERBOSE and reproduce the problem. Afterward, please follow the instructions in the following link to send us the debug log file:
Thanks for the log file.
Can you browse server files using ‘BROWSE’?
I removed the SFTP connection yesterday and since then I cannot add it again.
Can we have a short remote session to check the issue?
If possible please install JumpDesk connect and send me the Screen Sharing Link. When I try to connect you can authorize the connection.
Hi Having the same issue
sFTP connections are all ‘connection error’
Can still connect using clients like FileZilla etc
Please advise
Please send me the Screen Sharing Link using private message.
Do you have any updates regarding the issue?
I will post a fixed version here today. Sorry for the inconvenience is caused.
Following version includes fixes for SFTP connection. Please check if it works with your configuration.
The new version solved the issue.
Thank you for your support and quick prompt.
Great news! Thank you for informing us that the issue has been resolved.
