the connection to OneDrive Business was unexpectedly disconnected.
A reconnection is not possible - although it confirms that authentication is complete
The login in to a standard “OneDrive” is possible without any problems
Any idea ?
best regards
Alex
I am facing the same issue…please help
Rgds.,Wan
Sorry for the late response.
June 19, 2019, 1:11am
7
Hello customers. @949laundry @ass-schmidt @wanaziz
I found a error in log file.
HTTPS GET >> 503 : https://assspedition-my.sharepoint.com/_api/v2.0/me/drive(95)
It seems to be a temporary problem with the OneDrive for business server.
If the problem persists, please contact us again.
problem still exists.
best regards
No support …what do I pay for ???
Sorry for the delay.
For the authentication problem we need to check the certificate problem first.
Please update local CA certificates to recent version.
cacert.pem.zip (125.9 KB)
Unzip the above file and replace the cacert.pem file in NetDrive with unzipped cacert.pem file.
cacert.pem is located at C:\Program Files (x86)\Bdrive\NetDrive3\cert .
After replacing the file you need to reboot your PC.
The same problem although the new certificate.
What possibility have I to get the refund of the purchase price.
The program is useless for me without using OneDrive for Business.
