NetDrive version: 3
Windows/Mac Version: Windows 10
Hello, We are using OnDrive for business. Whenever we try to move a folder, it appears moved but after a minute or so it goes right back to the original location. I tried to check the log files but nothing gets logged by Netdrive. What might be causing this?
am not sure which one is the debug log file. I see about 5 logs files in the directory. I have attached the ones that were modified around the time I tried to move the folder. the folder Ind3svc_OneDrive for Business.zip (1.8 MB) tried to move is called zzMerrick. I can reproduce it anytime most folders don’t move.
my friend. I now have a bigger problem and is now VERY frustrated with your program. Since the upgrade, the “Shared with Me” folder that used to show up in onedrive for business has disappeared. This is a HUGE problem for us. We can’t work without this.
I have tried uninstalling and re-installing
removing the OneDrive for business and putting it back
Note: This happened on 2 separate computers so I halted upgrading my users.
Please let me know as soon as you can how i can get this folder back. For now, i have re-installed the older version.
Sorry for the delay. We need to change the API used by OneDrive and OneDrive for Business.
Please use following beta version. This version uses new APIs provided by Microsoft and it supports moving shared files in their folder (You cannot move files between separately shared folders). We will continue to test with this API and with some initial test it seems ok to share with.
This works. Thank you.
Do you know when it will be available in the regularly released version?
Also, how do i stop the program from popping up saying there is an available update (i did uncheck the box that says check for updates automatically)? Right now we have 30 users and would rather do the update at a time of my choosing or after it has been tested before having my users install it.
