I’m trying to connect to S3 Compatible Storage (Polycloud/CrowdStorage) but cannot establish a connection.
In the ‘Add a Personal Drive Window’ I have selected S3 as the storage type. After clicking ‘Connect’ I enter ‘https://polycloud.crowdapis.com’ as the server address and my AWS ID and SECRET. I haven’t been able to make a connection yet and was wondering if NetDrive supported S3 compatible storage?
Hi jyyoon, thanks for the response. I did enter my AWS ID and Secret. If you want to try it out yourself the platform I’m using is https://crowdstorage.com/.
Thanks for making the account and trying the connection. Were you able to get the connection to work successfully and upload/download anything? I’m entering the correct information in those fields and am getting a ‘please check server information’ error.
