NetDrive version: 3.7.687
Windows/Mac Version: Windows
I am probably not doing something but I do not know what. I am trying to mount a google team drive but am not sure how. I load up NetDrive3, press the plus sign in the bottom right hand corner, storage type -> Google Drive
Options, use team drive and show shared file/folders.
Give it a label, auto mount, mount on boot, use background uploading, writable drive,
then i press OK and CONNECT.
All I get is connection error. Is their nothing more to do?
Can you try disconnect/connect again on your drive config? I guess your google login credential has some problem. Google returns unauthenticated user error to NetDrive.
