Can connect to webdav drive but cannot mount it
I recently started using NetDrive3 and successfully mounted a few drives but I have a problem with my Webdav one. I click to add a drive and fill out the information. Netdrive3 successfully connects to my Webdav instance (I can see my folders by exploring the path). But when I click on “OK” to finish the installation, it just says : “Failed to add drive.”
Here’s what I see if I go in the logs :
[2021/04/11 20:42:03.137] [ERROR ] [ 3484] [NETDRIVE ] Failed to send command [{“cmd”:“get_mounted_drives”}] [c:\buildbot\slave-win\netdrive3_release\netdrive3\netdriveui\adddrive.cpp:1854]
[2021/04/11 20:42:03.137] [ERROR ] [ 3484] [NETDRIVE ] Failed to parse result of command [] [c:\buildbot\slave-win\netdrive3_release\netdrive3\netdriveui\adddrive.cpp:1876]
[2021/04/11 20:42:51.021] [ERROR ] [ 3484] [NETDRIVE ] AddDrive::event exception [c:\buildbot\slave-win\netdrive3_release\netdrive3\netdriveui\adddrive.cpp:1261]
[2021/04/11 20:42:51.022] [ERROR ] [ 11452] [NETDRIVE ] AddDrive::TryToConnect exception [c:\buildbot\slave-win\netdrive3_release\netdrive3\netdriveui\adddrive.cpp:1911]
[2021/04/11 20:43:32.911] [ERROR ] [ 19628] [NETDRIVE ] Failed to send command [add_drive] [c:\buildbot\slave-win\netdrive3_release\netdrive3\netdriveui\ndflatui.cpp:1813]
[2021/04/11 20:43:32.911] [ERROR ] [ 19628] [NETDRIVE ] Failed to parse result of command [] [c:\buildbot\slave-win\netdrive3_release\netdrive3\netdriveui\ndflatui.cpp:1829]
Couldn’t find infos on those errors. Hope you can help!
Dear Btm10,
Thank you for interest in NetDrive.
