Beta 3.12.246.1 still has an issue with logged on onedrive users in edge for chromium.
When I am making a onedrive drive in the new beta I get a bad gateway 502 error from the ignx web server when having to login. After I press F5 (Refresh) I get the “Authentication complete” screen.
Hi jyyoon,
When I tried to open the log directory the app changed language automatically.
First from Dutch to Spanish and then from Spanish to Chinese.
That looks like another major bug to me.
Hereby the log files of the original problem and this language problem.
I will have to reinstall the app since I can’t read the screens anymore.
Met Vriendelijke groeten, regards, mit freundliche Grussen, Cordialement,
Jan de Vries Lentsch
nd3log.zip (35.3 KB)
Does your issue with OneDrive persists?
I think there is no problem now.
Around that time, it was confirmed that there was a problem with the OneDrive server.
I will check another issue of you for languages.
Hi jyyoon,
The bad gateway problem still persists currently.
I also found out why the language was changed automatically:
When you scroll down in the settings panel with your mouse wheel and the language choice dropdown comes under your mouse pointer, the scroll through the settings is taken over by scrolling through the list of languages instead of scrolling further down the settings.
This should not happen. The language dropdown should only scroll after it has been selected by a mouse click first.
