Bdrive nd3svc is using a lot of CPU time (mostly above 40-50%). I have re-installed multiple times the NetDrive3 application but the problem still continues.
It runs on a Surface pro 5 I7 and 16Gb with the last version of W10 and the last version of Netdrive3. It is connected to a NAS in webdav mode.
Does anyone have the same problem?
Thank you for your help
May 31, 2021, 1:56am
