I’m receiving a “Authentication with WebDAV has failed” error when trying to add a drive. I’m also receiving the exact same error for existing mounted drives when I try to connect under config. I can connect to my drive when hitting the connect on the main screen. just fails when I go into “config” and hit the connect button there.
Dear developer-cdb3,
Thank you for using NetDrivie.
