Server specs:
Win10, Ryzen 1500x, cache drive on a 500gb SSD, connection to Google drive.
So I’ve noticed when I upload a file over 4gb, the drive just disconnects itself. But weirdly, it still uploads anything on the waiting list still, but I cannot access the drive at all. It turns into "local disk, and Plex or anything accessing the drive just goes into like pause, until that certain file uploads and is done. I can’t even get into the logs folder because of this.
I did some tests, and also found out that this was an explorer interacting with netdrive.
I put it on explorer-only transfer (not background). I then copied a 5gb file on the same system, and it reached 99%, showed up on netdrive as transferring, and stayed at 99% on explorer until it fully uploaded on netdrive.
So somehow, it doesn’t fully copy to the cache drive? or netdrive is using system resourced? Im also starting to get a memory leak because of this, sometimes the process is using 1.9gb of ram
