I met a problem , When using some software, it will tell me that there is not enough space.
When I switch back to the old version, it does work.
Im Using G Suite (edu ver.), Unlimit space.
In Windows 2012 R2. OS show Total Free: 1EB, use NetDrive ver.3.7.687, ARC Serve show no space, I reinstall NetDrive ver.3.6.571 , OS show free space is 10TB, and ARC Serve work fine.
It’s Netdrive new version update not considered well??
Have you mentioned that the current version of this feature has been added (V3.8.879)?
I see that the current version still does not have this feature optional…
I saw V3.8.921 on the release note of the website version history
Mention “you can manually set total space of drive items which does not provide space…Google Cloud Storage”
Should it be revised and mentioned later after the amendment?
