This has been available as BETA for 6 months (since 2023/06/15)
What features or benefits are found in this newest version?
When will this be finalized - or should we update to this now (2024/01/15)?
Dear gctmow-recovery,
The 3.17.976 (build 976) BETA version fixes some log output, so users who are not currently experiencing any issues do not need to update. You can install version 3.18 when it comes out.
Is there an issue with a login on a new version? It takes 10 minutes to go fail to login post update to 3.17.967
When 3.18 is out?
Dear leon-e5ed,
A new version will be released soon. Can you send us a log file for the issue that is preventing you from logging in?
- Reproduce the problem.
