I have been using CloudSync on a single machine since September. Yesterday it wouldn’t start up after crashing several times. Today I am getting the attached error about having reached the Maximum Devices allowed! I am only logged into a single device.
While there are 2 machines listed, only one shows Active. The other was only used for testing when I first tried CloudSync out. I cannot delete it. It has been there since Sept 2019 so why would it all of a sudden be an issue?
Ok, so I reactivated the machine I haven’t used in months. I then deactivated it and deleted it. I tried opening CloudSync again and guess what? I am now getting the below error! lol
I spoke too soon. While the app opened and logged me in, I am unable to click Sync Now and the auto-sync isn’t working either. Is that a licensing thing?
Sync Now and auto-sync isn’t related to the license limit.
I found that your device ID is recently changed. I’m not sure what caused the change but the device ID is read from Windows system and the ID can be changed by replacement of storage devices or network interface device.
If any of your sync item includes local disk as source or target and if the device ID is changed you cannot start the sync operation because local disk item only works from the machine where the sync jobs is first added.
I think you need to re-add your sync jobs from your current machine and it will fix the issue.
That makes no sense. I have this running on the same machine as I have always had it running on. The machine I deleted was just a test machine to see if I liked CloudSync, it was never used after my initial testing.
What device ID changed? So what is it that I need to do now?
