sync failed because source folder is not found,Change source to existing folder in config.
the folder is exist and user , password are correctly!
how can i fix it?
[2018/04/21 09:16:10.222] [MESSAGE ] [ 1160] [NETWORK ] [INFORMATION] Connection #0 to host xxx.xxx.xxx.xxx left intact
[2018/04/21 09:16:10.222] [DEBUG ] [ 1160] [PROTOCOL ] Protocol::Connect with explicit FTPS url:sftp://xxx.xxx.xxx.xxx:22/~, return 0
[2018/04/21 09:16:10.222] [DEBUG ] [ 1160] [PROTOCOL ] Protocol::GetFileInfo id: [/home/videos]
[2018/04/21 09:16:10.222] [DEBUG ] [ 1160] [PROTOCOL ] Protocol::GetFileInfo dir: [2]
[2018/04/21 09:16:10.222] [DEBUG ] [ 1160] [PROTOCOL ] Protocol::sftp_stat id: [/home/videos]
[2018/04/21 09:16:10.222] [MESSAGE ] [ 1160] [NETWORK ] [INFORMATION] Found bundle for host xxx.xxx.xxx.xxx: 0xd5fd070 [serially]
[2018/04/21 09:16:10.222] [MESSAGE ] [ 1160] [NETWORK ] [INFORMATION] Re-using existing connection! (#0) with host xxx.xxx.xxx.xxx
[2018/04/21 09:16:10.222] [MESSAGE ] [ 1160] [NETWORK ] [INFORMATION] Connected to xxx.xxx.xxx.xxx (xxx.xxx.xxx.xxx) port 22 (#0)
[2018/04/21 09:16:10.222] [MESSAGE ] [ 1160] [NETWORK ] [INFORMATION] Sending quote commands
[2018/04/21 09:16:10.238] [MESSAGE ] [ 1160] [NETWORK ] [INFORMATION] Attempt to get SFTP stats failed: No such file or directory
[2018/04/21 09:16:10.238] [MESSAGE ] [ 1160] [NETWORK ] [INFORMATION] Connection #0 to host xxx.xxx.xxx.xxx left intact
[2018/04/21 09:16:10.238] [ERROR ] [ 1160] [PROTOCOL ] Protocol::sftp_stat id: [/home/videos] , exec error: [21]
[2018/04/21 09:16:10.238] [ERROR ] [ 1160] [CLOUDSYNC ] Source folder not found
[2018/04/21 09:16:10.376] [MESSAGE ] [ 980] [CLOUDSYNC ] Sync ct-31 done
when i use the beta release 2.2.334
the system show lost libssl-1_1.dll
how can i fix it?
We didn’t release 2.2.334 yet. How did you download it?
change the link
(ˉ▽ ̄~)
but can you help me to find what wrong with 2.2.327
the post shows
Can you change sftp options?
Try ‘System root’ option please.
i change the mount point
but the files do not show correct.
it has the same files
hwo can i fix it?
Ok. I see. I’ll check your issue and let you know when I got something.
thank you very much
