CloudSync (2.0.269 (build 269)) will not connect via webdav to my Seagate MyCloud local NAS after latest update. I can use the same configuration with the NetDrive 3 (3.1.286 (build 286)) and it works perfectly.
[DEBUG ] [ 1284] [PROTOCOL ] Protocol::GetFileInfo >> ON HTTP RANGE 200(207) : SUCCESS(0x00000000)
[2017/12/21 13:15:13.677] [ERROR ] [ 3304] [PROTOCOL ] Protocol::Connect >> URL using bad/illegal format or missing URL(3)
[2017/12/21 13:15:16.786] [ERROR ] [ 1284] [PROTOCOL ] Protocol::Connect >> URL using bad/illegal format or missing URL(3)
If you give me a place to upload the entire log file I will do that without issue. It works fine with NetDrive which is puzzling. I also verified the credentials by logging into my NAS and verifying the WebDav URL.
WooHoo. I see the beta versions clicking along. Is it fixed in any of the beta releases? If so, even though I have that option checked the beta software is never installed or an option given to install it. Thank you for letting me know.
NetDrive works OK, it is CloudSync that cannot connect to Seagate Personal Cloud via WebDav. It is still not working in the latest beta. I just tested it.
