How can I setup remote path for WebDav Drive?
So far I’ve used URL like this: http://domain.com:123/path/path
but after connect, folders in specified path shows empty.
Is it any other way to do it?
Please check webdav port is correct or not.
Or path must be url encoded.
Everything is correct and Drive is connected with remote path, only thing is it shows folders from remote path but them all empty.
If I remove remote path from URL it works fine.
This topic was automatically closed 6 days after the last reply. New replies are no longer allowed.
