Updated to 3.6.498 now SFTP upload not possible
NetDrive version: 3.6.498
Windows/Mac Version: Windows 10
When saving a file in my editor (Sublime editor 3) i’m getting error “failed to upload”.
Log file snippet:
[2018/07/31 11:00:54.126] [MESSAGE ] [ 8668] [NETWORK ] [INFORMATION] Upload failed: Permission denied (3/-31)
[2018/07/31 11:00:54.126] [MESSAGE ] [ 8668] [NETWORK ] [INFORMATION] Connection #0 to host xxxxxxxx left intact
[2018/07/31 11:00:54.126] [ERROR ] [ 8668] [PROTOCOL ] SFTP::Upload id: [xxxxx.htm] , exec error: [9]
[2018/07/31 11:00:54.135] [MESSAGE ] [ 8668] [FILESYSTEM] Upload - xxxxx.htm(/xxxx/xxxx/xxxx/xxxxx.htm) done(Failed)
[2018/07/31 11:00:54.135] [DEBUG ] [ 8668] [NOTIFIER ] [Z:NE_UPDATEITEM] : 5, Z:\xxxx\xxxx\xxxx\xxxxx.htm,
[2018/07/31 11:00:54.135] [DEBUG ] [ 8668] [NOTIFIER ] [Z:NE_FREESPACE] : 5, ,
[2018/07/31 11:00:54.135] [DEBUG ] [ 8668] [FILESYSTEM] Decrease WriteCount xxxx\xxxx\xxxx\xxxxx.htm, 0
[2018/07/31 11:00:54.135] [DEBUG ] [ 8668] [FILESYSTEM] [Z:PID 4] Handle 2246 destroyed
[2018/07/31 11:00:54.135] [DEBUG ] [ 8668] [FILESYSTEM] [Z:PID 4] FileSystem::Release => AERROR::SUCCESS : xxxx/xxxx/xxxx/xxxxx.htm
Does it happens on 3.6.498(beta) only? How about 3.5.434(current release)?
The current release works fine (we switched back to this version now).
Ok. I’ll check 3.6.498(beta) again.
Thanks!
We had the same problem. Please fix the SFTP functionality with your Beta and do NOT release it to a major version until it’s fixed.
Sure. That’s why we release beta before official release.
Hi Alex,
You’re absolutely right. I understand and was just frustrated with it.
Do you happen to default NetDrive to update beta versions? Mine was set that way, but that might have been something I toggled.
