I’ve been using Netdrive on my PC for years, and recently on my MacBook. The configuration syncs via the cloud, but I’m having trouble locating the SSH key:
On Windows, the SSH Keys are located: D:/Data/!CONFIG/SSH_KEYS/…
and on MacOS: /Users/slawek/Data/!CONFIG/SSH_KEYS/…
I have so many remote locations configured that I don’t want to duplicate them.
How can I achieve a single universal configuration for both PC and Mac?
Currently, NetDrive does not support specifying a universal SSH Key path that works across both Windows and macOS. At this time, you need to configure the SSH Key path separately on each operating system.
However, we understand the inconvenience, and we are planning to improve this by allowing separate SSH Key path settings for Windows and macOS in a future update. Once this feature is available, you will be able to use the same remote more conveniently across both platforms.
Thank you for your valuable feedback. We will notify you once the improvement is applied.
