I have various users using ND2 with no issues. I have one user that is using NetDrive3, connecting to a server using WebDAV and mapping a drive locally.
ND connects fine and I can see the data on the share on her laptop. When she tries to save any kind of file to it, it immediately comes up: “Failed to upload”.
The file shows in the local mapping, but does not show on the server.
I have installed ND3 on my PC and set up the same as my customer (with a new user account on the server) and am having same issue.
Interesting note: if I create an empty file, such as an empty notepad file, it uploads fine. If I put anything in the file to change it from 0bytes in size, it fails.
This is the error I get in Windows:
When I select “Skip” WIndows Event log shows the following error:
Log file from ND:
[2022/11/03 08:54:57.421] [ERROR ] [ 8084] [SERVICE ] [ nd3 sdk version - child nd3svc : 3.16.667 ] [Child.cpp:129]
[2022/11/03 08:55:50.117] [ERROR ] [ 5420] [PROTOCOL ] WEBDAV::WebDAV::Upload >> Send failed since rewinding of the data stream failed(65)
[2022/11/03 08:55:50.685] [ERROR ] [ 9612] [PROTOCOL ] WEBDAV::WebDAV::Upload >> Send failed since rewinding of the data stream failed(65)
[2022/11/03 08:55:50.686] [ERROR ] [ 9612] [FILESYSTEM] Failed to upload : ~$ec Tile.docx [filesystemimpl.cpp:1225]
[2022/11/03 08:55:51.661] [ERROR ] [ 8768] [FILESYSTEM] [W:PID 4] FileSystem::Release => AERROR::INVALID_HANDLE : ~$ec tile.docx
[2022/11/03 08:57:49.870] [ERROR ] [ 1940] [PROTOCOL ] WEBDAV::WebDAV::Upload >> Send failed since rewinding of the data stream failed(65)
[2022/11/03 08:57:49.888] [ERROR ] [ 3292] [FILESYSTEM] FileOperation::WriteFile : AERROR::FILE_WRITE_FAILED
[2022/11/03 08:57:49.888] [ERROR ] [ 3292] [FILESYSTEM] [W:explorer.exe] FileSystem::Write => AERROR::FILE_WRITE_FAILED : spec tile.docx
[2022/11/03 09:00:05.839] [ERROR ] [ 19848] [PROTOCOL ] WEBDAV::WebDAV::Upload >> Send failed since rewinding of the data stream failed(65)
[2022/11/03 09:00:05.869] [ERROR ] [ 3292] [FILESYSTEM] FileOperation::WriteFile : AERROR::FILE_WRITE_FAILED
[2022/11/03 09:00:05.869] [ERROR ] [ 3292] [FILESYSTEM] [W:explorer.exe] FileSystem::Write => AERROR::FILE_WRITE_FAILED : spec tile.docx
[2022/11/03 09:02:13.270] [ERROR ] [ 21508] [PROTOCOL ] WEBDAV::WebDAV::Upload >> Send failed since rewinding of the data stream failed(65)
[2022/11/03 09:02:13.280] [ERROR ] [ 5420] [FILESYSTEM] FileOperation::WriteFile : AERROR::FILE_WRITE_FAILED
[2022/11/03 09:02:13.280] [ERROR ] [ 5420] [FILESYSTEM] [W:explorer.exe] FileSystem::Write => AERROR::FILE_WRITE_FAILED : spec tile.docx
[2022/11/03 09:04:27.167] [ERROR ] [ 21544] [SERVICE ] [ nd3 sdk version - child nd3svc : 3.16.667 ] [Child.cpp:129]
[2022/11/03 09:04:45.626] [ERROR ] [ 19032] [PROTOCOL ] WEBDAV::WebDAV::Upload >> Send failed since rewinding of the data stream failed(65)
[2022/11/03 09:04:45.640] [ERROR ] [ 17172] [FILESYSTEM] FileOperation::WriteFile : AERROR::FILE_WRITE_FAILED
[2022/11/03 09:04:45.640] [ERROR ] [ 17172] [FILESYSTEM] [W:explorer.exe] FileSystem::Write => AERROR::FILE_WRITE_FAILED : spec tile.docx
[2022/11/03 09:05:25.673] [ERROR ] [ 1916] [PROTOCOL ] WEBDAV::WebDAV::Upload >> Send failed since rewinding of the data stream failed(65)
[2022/11/03 09:05:25.696] [ERROR ] [ 10284] [FILESYSTEM] FileOperation::WriteFile : AERROR::FILE_WRITE_FAILED
[2022/11/03 09:05:25.696] [ERROR ] [ 10284] [FILESYSTEM] [W:explorer.exe] FileSystem::Write => AERROR::FILE_WRITE_FAILED : vendor/spec tile.docx
[2022/11/03 09:07:22.915] [ERROR ] [ 19572] [FILESYSTEM] W FileSystem::UploadCacheCancel => AERROR::FILE_NOT_FOUND : ~$ec Tile.docx
[2022/11/03 09:07:22.937] [ERROR ] [ 19572] [FILESYSTEM] W FileSystem::UploadCacheCancel => AERROR::FILE_NOT_FOUND : Spec Tile.docx
[2022/11/03 09:07:22.960] [ERROR ] [ 19572] [FILESYSTEM] W FileSystem::UploadCacheCancel => AERROR::FILE_NOT_FOUND : Vendor\Spec Tile.docx
[2022/11/03 09:08:42.986] [ERROR ] [ 10284] [PROTOCOL ] WEBDAV::WebDAV::Delete >> HTTP 404
[2022/11/03 09:08:42.986] [ERROR ] [ 10284] [FILESYSTEM] [W:explorer.exe] FileSystem::Unlink => AERROR::FAILED : \New Text Document.txt
[2022/11/03 09:08:58.757] [ERROR ] [ 1360] [PROTOCOL ] WEBDAV::WebDAV::Upload >> Send failed since rewinding of the data stream failed(65)
[2022/11/03 09:08:58.768] [ERROR ] [ 21468] [FILESYSTEM] FileOperation::WriteFile : AERROR::FILE_WRITE_FAILED
[2022/11/03 09:08:58.768] [ERROR ] [ 21468] [FILESYSTEM] [W:explorer.exe] FileSystem::Write => AERROR::FILE_WRITE_FAILED : new text document.txt
[2022/11/03 09:35:27.725] [ERROR ] [ 7988] [PROTOCOL ] WEBDAV::WebDAV::Upload >> Send failed since rewinding of the data stream failed(65)
[2022/11/03 09:35:27.734] [ERROR ] [ 18340] [FILESYSTEM] FileOperation::WriteFile : AERROR::FILE_WRITE_FAILED
[2022/11/03 09:35:27.734] [ERROR ] [ 18340] [FILESYSTEM] [W:explorer.exe] FileSystem::Write => AERROR::FILE_WRITE_FAILED : spec tile.docx
The server that these files are uploading to is an older Windows 2008 R2 server. Not sure if that has anything to do with it. From what I gather, it has worked for her since we first installed but now it is not so not sure what changed. Any ideas would be great.
Thanks.
Chris
