We are unable to copy file greater than 1 mb from Source to Destination
Error message : The request could not be performed because of an I/O drive error(refer the attached)
Can some one help us regarding the issue
Having the same issue, just installed the trial version. The trial isn’t going well!
If you had the same issue in May with no response guessing this software isn’t ready for primetime. Disappointing as I had high hopes this would solve some storage issues, backing up data to OneDrive.
Grateful for the trial version, saved me from finding out it doesn’t work after paying for it.
