I have a laptop with a 4K UHD display. The Netdrive 3 displays are way too smal and I can barely read them. I had a similar issue with a previous update and received a patch. Is it also possible to receive a patch to correct this issue?
Setting QT_AUTO_SCREEN_SCALE_FACTOR to 1 does set the NetDrive3 window text and graphics back to its previous version’s size. However; the window stays in full screen “mode” and its size can not be changed. The full screen toggle in the upper right corner does work, but does not change the size of the window and I can not use the courser to resize the window. The window can be minimized and closed.
Adding Q T_SCALE_FACTOR with a 1.5 value makes the text and graphics very large and the window stays in full screen “mode” as discussed above.
Only setting QT_SCALE_FACTOR to 1.5 and not specifying QT_AUTO_SCREEN_SCALE_FACTOR, slightly increases the text and graphics size and causes the same full screen issue discussed above.
Soooooo… Setting QT_AUTO_SCREEN_SCALE_FACTOR to 1 works as long as the NetDrive3 window being stuck on Full Screen “mode” does not interfere with doing the task at hand.
An Update… I just discovered setting QT_AUTO_SCREEN_SCALE_FACTOR to 1 is impacting 2 other APPs, making their screens way tooo big to use and their size also can not be modified with this setting. So… setting this variable is not a sustainable solution for me…
