I have a huge problem. I set up a WebDav server on my Synology server and I using with NetDrive3 and works well. I have a huge folder structure with very deep parts and I realized can’t open my file if the path is too deep. I can see all files in deeper folders but when I try to open them, the error message: “Can’t open becuase the file was moved or delete” or something similar depends on software.
I tried mounted as local drive and network drive, I can go deeper when I mounted as network drive, but not deep as the structure finished.
Allright, but how can I solved it? because when I connected the webdav network drive its open automatically in windows file explorer. I tried open in TotalCommander but it also has a 260 character limit.
You should follow this to windows explorer accepts long path names.
(1) run regedit.exe as administrator
(2) locate [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\FileSystem]
(3) change data value [LongPathsEnabled] (DWORD) to “1”
(4) close regedit and restart Windows
