Is it possible to use Netdrive with storj or Tardigrade. Looking for an easy way to make it so I can use their solution for storage
Sure you can use Tardigrade and Storj becuase both of the services are S3-compatible.
Select S3 as your storage type and click Connect button.
You can change server address to Tardigrade’s or Storj’s to access the storage.
