I had all of my network attached drives (smb to local server) dismounted because the server was being updated. Updated NetDrive3 to this version on my Mac and when I started NetDrive3 it mounted 80% of my smb mounted disks on my local server. Stopped NetDrive3, unmounted drives, restarted NetDrive3 and disks were all mounted again. None of these drives are configured in NetDrive3 and NetDrive3 is not set to automount anything on startup.
100% correct. If my SMB drives are not mounted (on my Mac) and I start NetDrive3 it mounts my SMB drives. I they are mounted and I start NetDrive3 it mounts them a second time.
This only happens if NetDrive3 is not already running and I start it up (as in after an upgrade or after manually stopping it).
SMB mounted drives that are not connected when NetDrive is started are reconnected as soon as NetDrive agent completes and panel is displayed on the screen
There are no drives set to auto mount in NetDrive on startup. All mounts are supposed to be manual on this machine.
