NetDrive version: Current
Windows/Mac Version: Windows 10 build 1803
Some applications that make standard windows api calls to find drives & paths are not detecting NetDrive mounted volumes. For example, I use an extension for Chocolatey that makes a backup of my installed applications (choco-package-list-backup) and if given the path to a regularly mapped drive the location is found and the backups are created. If the drive & path provided is a NetDrive mounted volume the application fails to create the backups. I have tested with other windows applications and the same situation is occurring in many instances.
