Problems with Netdrive - File Lock Service is not available
Since few days ago I am getting the error Netdrive File Lock Service is not available in the icon tray, data transfer is very slow and the bdrive services crash very often, could you please connect remotely to have a look?
Thanks!
Dear informatica-c2f3,
Please check if you can open following page on machine where NetDrive installed.
https://push.bdrive.com/
yes it opens and says ¨It works¨ I tried that before, and did not solve the problem…
We confirm that several users using Windows now experience the problem and we are looking into the issue.
Please let us know as soon as you find the solution, thanks!
@informatica-c2f3
We changed websocket library. Please check with following beta version if you still have the problem.
https://files.bdrive.com/netdrive/builds/5e8690dcb9134a328c212f1e642206a9/NetDrive3_Setup-3.17.791.exe
Thanks for using NetDrive.
