I have followed all the steps, but I only get an error message.
Any help, please?
I need more clues. Can you give me debug logs? Please refer this article and pm to me.
Hi.
I can not make a log because I can not create the drive unit at first.
I send you step by step what I did.
I await your help. Thank you.
** REMOVED FILE **
I’ve checked it several times.
I get everything right only if I have 1 register in ‘Cloud Service Secrets’ https://accounts.bdrive.com/accounts/cloud_service_secrets/
When I put 2 or more registers, I can no longer connect the second unit, and the error reappears.
Please help.
Sorry that we’ve missed your message.
I will check there is a problem when there is multiple client ID registered.
I still have the same problem, could you verify it?
@cabaseira We fixed the issue and it will be applied to production server today. I will update you when it’s ready.
The fix is applied to production server.
I have checked it. It works perfectly. You are doing a great job with the app. Cheer up!
Thanks and sorry about the delays.
