ysh
December 22, 2017, 7:45am
#1
File lock for WebDAV
Client-side file encryption
Shared drive item for teams
Private key based encryption of user data
Command line interface (CLI) to mount / unmount drive
New protocol / cloud service support like Backblaze B2, Wasabi, etc.
Master password to change settings, or add/remove drives
Offline file and folder access (Sync later when online)
Auto reconnect on connection failure
Multilanguage installer & GUI
Option for limiting bandwidth
IPv6 support
Feel free to suggest a new feature.
NOTE: API for Google Drive ‘Computers’ does not supported by Google (yet).
Vote for auto-reconnect. Also will be nice, if:
files with failed upload will be resended/reuploaded in ~10…60 minutes interval;
option ‘delete then replace’ if file exist at destination and must be replaced;
Cache for uploading will be nice, but… see above. If You write >100 files in cache, and then need to control manually, which is uploaded, and which not…
One more, after today games with last build … Will be nice, if drive page ‘on each drive picture’ have, potentialy, up to ~4 icons for:
‘uploading now’;
‘downloading now’;
‘have failed files’;
‘have files waiting transfer’;
Yes, most part of this information is on ‘uploading’ tab, but…
