I have purchased Netdrive 3 but somehow I cant login right after that.
I had used the trial version before and it worked well. But after moving to the licensed version, the software keeps saying login failed even I tried every possible ways and every supported type of connection on Netdrive.
My OS is Windows 10 and Webdav server.
Can somebody give me any valuable advice. Thank so much.
I’ve checked your account and I found that you registered your id using Google Login. Please try login with Google not with your email address and password.
