when trying to connect to One Drive I get the error message 402 Bad Gateway. Access works with Dropbox, though. How can the problem be solved?
Also like other people posting on this forum I have the problem that I can hardly read the print of NetDrive.
Is there an update addressing this problem?
sumavax
Please try OneDrive (Graph API).
Unfortunately this does not make any difference. There is the same message 402 Bad Gateway.
Does the issue persists?
I checked it now, but the problem is not reproducing.
Thanks for your reply.
As the problem persisted yesterday I removed Netdrive from my computer. I think using it is not such a big advantage in comparison to accessing OneDrive with the integrated explorer app (WIN 10) anyway.
Armin stelzer
