Issue is still there. I have renember checkbox enabled, loging in, and it will ask for credentials again after reboot.
In settings, set Log level to “DEBUG” and then reproduce your problem.
In your case to reproduce, re-login after logout.
Then compress the folder “C:\ProgramData\NetDrive3” and attach the zip file at here.
It will be very helpful to find and solve the problem.
Thank you again.
