I’m always asked to login to netdrive 3 when launched at windows start.
I give up, tha’ts too annoying, how to go back to netdrive 2 ?
Same problem here.
Could you check this issue with a test version?
The test version can be downloaded from following url.
http://files.bdrive.com/netdrive/builds/NetDrive3_Setup-3.1.247.exe
Same problem here. the link doesn`t work…
AccessDeniedAccess Denied26B92EAC358F5104ln6WZgcX+goYiSataNbQh5Jfl0YgUfq6xIeSpcBmMoLPEnK89dN+28P1deKRLJLLX1bpFPvSaK4=
The link doesn´t work
@alexandre.emeriau @Eurolicht
The correct link is: http://files.bdrive.com/netdrive/builds/NetDrive3_Setup-3.1.247.exe
I tried 2 restarts with the newest version, and it seems that work correctly
Sorry, I fixed the link.
Try again, please.
Do you have an update with no virus in it? or not catched as a virus by avg or zemana for example ?
