NetDrive3 won't connect to Dropbox for Business
I can’t get Netdrive3 to connect to my Dropbox business account. I enter my login details and grant access, but it just hangs with the spinning circle. It’s showing up as authorised in Dropbox.
I’ve tried 3.14.309 & 3.15.393. I’m running Windows 10 20H2.
I’d really appreciate some help.
Thank you
NetDrive3_chris.zip (5.2 KB)
If you have problems adding the drive item, this issue can be solved by installing a root certification to your machine.
Please download attached comodo_root.zip file and unzip it.
comodo_root.zip (1.5 KB)
Then, install to “Local Machine”.
If the certification is installed, you can add a drive item normally.
Please try to add and connect after installing the certification to “Local Machine”.
This worked. Thank you for your prompt support!
This topic was automatically closed 60 minutes after the last reply. New replies are no longer allowed.
