Why I can’t define a Drive letter like in Netdrive 1 ? Netdrive 3 always takes a drive letter i already use !!!
You can assign a drive letter, go into config of the drive you are configuring and where it says mount (underneath label), you can choose a letter, make sure the drive is disconnected first. If the letter you want is already assigned to another drive, you will need to unassign it first.
