Hello good morning, I need help. The NetDrive connection with my Dropbox account stopped working today 10/08/2024. I went to the application settings in the dropbox panel, removed NETDRIVE and tried to authenticate again, but it only gave an error, I’m sending the screenshots as attachments. I’m using Net Drive 3 3.17.960. Can you check urgently please?
Hey Dropbox, are you assholes going to deal with this!@
Having same issue
We have just been made aware of the Dropbox issue you mentioned. We are actively investigating the root cause of the problem with the Dropbox connection.
Rest assured, we are doing everything we can to identify and resolve this issue as quickly as possible to minimize any inconvenience. We will keep you updated and notify you as soon as a solution is found.
We sincerely apologize for the inconvenience this has caused, and we appreciate your patience. We will provide updates as soon as they become available.
The Dropbox issue has been resolved, and you should now be able to use Dropbox with NetDrive without any problems. Please try logging in again to restore your connection.
However, during the login authentication process, you might see a warning message. This is due to the ongoing review of the new authentication keys. Please feel free to ignore the warning message for now, as it will not impact your usage. Once the review is complete, the warning will no longer appear.
We apologize for the inconvenience and appreciate your patience. Thank you for your understanding, and we remain committed to providing you with the best service possible.
still not able to connect
The issue should be resolved now, and you should be able to access Dropbox without any problems. If you are still unable to connect, please try re-logging in.
If the issue persists, we recommend clearing your browser cache or trying with a different browser. If the problem continues, please don’t hesitate to let us know, and we will be happy to assist you further.
Thank you!
Works for me.
I opened the Config screen and clicked Connect. The Dropbox page asked to confirm that I trust this developer. I confirmed. Problem solved.
