Netdrive 3 Installation Issue
I am having issue to install NetDrive 3 on my client’s Win7 Ultimate version. The installer kept end prematurely. Where is the log I can retrieve to see where the problem is?
I had tried different Netdrive3 versions and all having same issue.
Have you installed NetDrive using a user with administrator privileges?
Or if you attach log files to figure out I will review them.
The path of log files are “%TEMP%\Bdrive”.
C:\Users\username\AppData\Local\Temp\Bdrive\NetDrive3_Install.log
C:\Users\username\AppData\Local\Temp\Bdrive\NetDrive3_Setup.log
