I’m using Netdrive 3 on Windows 10 with a Webdav to a Synology Nas. The IP I use for Webdav is my public IP address and if i’m outside my home network everything works fine. But as soon as I’m in my home network everything is very very slow, and most of the time not even working. Is there a relation to Netdrive with the Webdav to the public IP?
I guess it might be relative with your network environment or router.
Can you browse the mounted drive?
I guess you cannot browse it at all.
Some routers refuse to connect to the internal public IP in LAN.
