netdrive does not respond to connect or disconnect drives more possible
why is that?
Hello Kohlys-software.
Which version are you using?
I think if you install 3.6.571 BETA, your issue will be fixed.
http://files.bdrive.com/netdrive/builds/d459a3ca4c0341d7ba2102b42ae61921/NetDrive3_Setup-3.6.571.exe
