My copy of Netdrive 2 works perfectly on my Win 10 machine, however, I just installed the latest version of 3 and its unusable.
I really need a WebDav connection, but Netdrive 3 crashes when I go save a new connection.
Any ideas on how to troubleshoot this issue?
Do you use beta version?
Hello, i have the same issuewith beta version, i try with normal version
Same issue with normal version, dunno hat is happening.
Can you send me using private message the screenshot of add item screen just before clicking OK button?
Dear customers.
Sorry for inconvenience.
Could you check your issue after download from the following url and install it?
http://files.bdrive.com/netdrive/builds/NetDrive3_Setup-3.3.354.exe
