I found only a couple of threads back from 2020 and assumed the issue was fixed, but here it is yet again:
BSOD 3 times in a day after trying to connect to a Synology NAS and mount it as a local drive.
Two mini memory dumps show the same driver: cbfs6.sys:
MODULE_NAME: cbfs6
IMAGE_NAME: cbfs6.sys
STACK_COMMAND: .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET: 14ba
FAILURE_BUCKET_ID: 0x22_cbfs6!unknown_function
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {35fab941-f3c9-7822-be64-419495e32a07}
Followup: MachineOwner
Dear alexei104
Could you try installing the version below? This version has transitioned from using CBFS to WinFsp, which may resolve the issues you are experiencing.
https://downloads.bdrive.com/netdrive/builds/35b70adf93824d429466de715550a548/NetDrive3_Setup-3.18.1078.exe
Best regards
Thank you, tsjeong! The new version that uses WinFSP works.
I confirm that I had BSOD on one of my three laptops, the one where I needed Netdrive the most.
Your fast response is much appreciated!
Dear alexei104,
Glad to hear it worked out for you. If you run into any other issues, please don’t hesitate to let us know.
Best regards
