I have a problems copy file to any cloud drive and error “Access denied” on Netdrive 3 app for Windows 10 Home 64-bit Build 1709 on Netdrive 3 version is: 3.1.234.
3.1.218 is okay, no problems.
Can you fix it?
Reply me ASAP.
Colin.
Can you fix it?
Reply me ASAP.
Colin.
I am having the exact same issue using 2008 Server R2. I can manually do stuff, like copy and create directories, but scripting in any way, shape, or form causes an “Access denied…” error. I’ve tried several backup products, like SyncBack Pro and they fail as well.
No solution in any of the support topics that I have seen.
Grrrrrrrrrrr…
Jeff.
